- Thread starter
- #21
Thanks, and I will check that this weekend, code check on pins A&B did 12 three times, 41 three times and 12 three times, so it would be code 41, which is check wiring at ECM, poss prom failure or incorrectly seated prom. I will check and clean these. What is the best way to check ASR motor,, and I will check on forum also
Great...ECM connection maybe, hope it resolves it. What I meant by the asr motor check was the cables. Make sure there is not a lot of slack in any of them. I may have gotten on my car at the time when it happened so not sure sure if it would be affected by sudden stop. Anyway Sam, I have the manuals for the car if you need any info I can e-mail it to you. Sounds like you're on the right track though. Don't forget the codes will be erased when battery is disconnected on ODB1 which our cars have. The 94 started with OBD2.
Throttle cable was loose enough to come off of cam, adjusted it with just slight tension in the cable. Every thing in ASR was snug except throttle, now all are snug. Thanks
