boomdriver
easy enough to pull suspect inj and connect to a pump and watch the spray. A wire that can be used to make contact can be used to "cycle" the injector to see if its late or slow to keep up.
Unless there is damage or known cause why this one inj has failed, it causes you to replace 8. Absolutely foolish to replace a single inj when all have to be accessed to get that one...may as well do 7 more for peace of mind, and because you have to do O-rings anyway,.
Good luck
Good luck
ad
