A
AustinJohn
I have long suspected the LT1 in my '94 coupe (with automatic) might not be the original engine because of some strange electrical splicings, among other things. So as shown in my 1994 Factory Service Manual I removed the ignition coil module for access to the number pad, cleaned the pad but found only "V0204ZWA" which confirmed I had the correct engine for my '94 automatic but the VIN derivative series that would indicate if the engine was original to the car was not on the pad. Apparently if the VIN derivative series was originally on the pad someone removed it and thus I assume I do not have the original engine. If the numbers were removed who and why and when, I don't know; I guess it just adds to the Corvette mystique. But, in the meantime, fortunately its a strong running engine.
Then someone with friends who are NCRS judges showed them a picture of my number pad and they said the number pad appeared unaltered and my second set of numbers was probably on the driver's side rear block just below where the cylinder head mounts. But after spending literally hours searching that location plus near the oil filter and on the the driver's side of the bell housing (other suggested locations), I'm still striking out.
So I'm asking any '94 LT1 owner out there who might know where the VIN derivative series is to give me a clue. Many, many thanks in advance!
John
John
