vetteoz
There are conversion harness to put LT1 in cars and TPI in cars; not one to make LT1 PCM (Optispark ) work with TPI ECMHas anyone called PainLess wiring for adptors & harness sections? THEY can help....conversions are the specialty.
There is also the issue of trans control.
If his '94 has a 4L60E then it needs the '94 PCM ( Powertrain Control Module ) to control trans shifts which takes some of it's inputs from the engine .Standalone Elec trans controller @ $1000 unles you retrofit a 4L60
