96 CE wipers will not turn off
gmhowe
glendale, az
1985 4+3 black cpe & 96 LT1 CE
Turned on the wipers yesterday ( and yes we have to use out wipers even here in Phoenix sometimes :L), then they wouldn't shut off had to turn off and on the engine then they would shut off. Any ideas would be most appreciated.
Gordon
I suspect you have either a short in the wiring somewhere or a failed multifunction switch in the steering column.
You need the Factory Service Manual for its wiring diagram for the wiper/washer system and you need it for the instructions on how to replace the switch if diagnosis points at the switch as the problem.
As for tools, you may need a DMM and, you may need some special tools to partially disassemble the steering column if the multifunction switch needs to be replaced.
Thanx Hib as always will look it up to see what is needed
Gordon
OK so according to the FSM I have a "Faulty Park Switch" anybody have a part number. Checking on Amazon I get a whole slew of relays/switches so not sure which is right one
Thanx
Gordon
