digimc
About two months ago I had a soft brake pedal problem which resulted in the brake booster, master cylinder, ABS valve unit and one caliper being replaced. All was good after the replacement parts (about 300 miles) until I went to use the car today and while backing out of the garage found that I needed to apply major pressure to the pedal to stop the car. The pedal was rock hard! No sinking or rising pedal. I have proper vacuum at the booster and no hissing anywhere. The car rolls fine but is completely unsafe to drive as it is hard enough to stop at rolling speed much less highway.
The car has a total of 23000 miles and is well maintained although it sits on the storage lift too much. Any suggestions are appreciated.
