96CE...Changing clutch hydraulic system
  • Thread starter Thread starter vettfvr
V
vettfvr
For my Memorial Day corvette project I am replacing the clutch hydraulic system on my 96CE LT4...master/slave cylinders and connecting hose. Question: When installing the slave cylinder, is there a receiving area/port to "aim" the actuator arm at. Is it easily visualized? Any advise/suggestions appreciated.:pat
Installation is the reverse of removal. The actuator will "automatically" contact the clutch fork.
Just make sure that when you bleed the slave you position the slave cylinder at a 45 degree angle so the bleeder valve is at it's highest point.
