Jim Shoemaker
- Joined
- Sep 23, 2001
- Messages
- 40
- Location
- Manassas, VA, USA
- Corvette
- 1997 Arctic White Coupe Firethorn Red interior
My vette's been sitting in the garage for a couple months and I decided to give it a wash and wax today. The battery appeared dead when I went to start it, so I decided to jump it according to the owner's manual. As I connected the ground to the vette, the defroster fan began blowing (key wasn't even in the ignition!). Got it started and the fan continued blowing even though the climate controls all appeared to be off. I pushed the fan speed control down and the AC and recirculation buttons both lit up but the fan stopped blowing. Pushed the off button and both buttons went out, but the fan started again. Now I'm getting a bit confused. I also noticed that about every 5 seconds or so the clock would dim like there was excessive draw on the electrical system. I got out and listened to the engine idle and heard a clicking sound (like an electrical relay) that coincided with the clock dimming coming from the engine compartment fuse box. I turn off the car and the fan keeps blowing until the battery goes dead again. I had a battery leak a couple years ago that also affected the wiring harness so I checked to see if I had another leak (still using an AC Delco sidepost battery). No leak was evident and the wiring seemed okay. Anybody got a clue? Sorry, but I neglected to check the error codes before the battery went dead again.
Jim
Jim
