Buckskin7T7V
Did any of you see the news item a couple of days ago, on the bacteria and mole found in ac evaporators?
There is a product that will clean out the system, but I did not have time to write it down. It is a foam, that you spray into the system.
It was also mentioned, that it is very important, that the system drain is open and not blocked. I have noticed, that my Toyota a/c has a drain and when I run the a/c, it drains a lot. The only condensation I see coming out of the vette, is the same drips from the compressor hose. Is there a drain vent on the system. Mine is a 77?
:confused
:confused
