A
Alfonso Gomez
My 1987 Coupe has auto climate control. Right above the controls there is a small window which I understand is a LED readout. There you know the outside temp, fan speed, etc. The trouble in my car is that that display goes on and off periodically. I guess it may be a loose connection or cable. Any of you have had the same problem? I know that to check it I have to remove the center panel but Iwould like to have some ideas before I start taking evrything apart.:eek :crazy
Goog luck Charlie
