Weather is finally warm here. Had the car out yesterday, 80 degrees + and the air conditioner worked fine. Took it out again today and nothing but warm air.
Checked the compressor, clutch engages when switched on and operates freely, fan goes to high speed on max. Don't have guages to check freon pressure. If I do have a leak, is now the time to convert to new style freon ( R-134?). If so, how costly is it. What needs to be replaced. Tried searching old threads, but no results.
Thanks,
Murf
Thanks,
Murf
