KikiPhillips
Problem: Fire up the engine, Put A/C switch to Defrost, Low speed works, Medium, High also work. Put the lever to Vent, it opens up the vent flap and all the speeds work properly. Move the switch to Normal and the blower stops blowing on all speeds....and the flap closes.
If I go from Vent to Maximum, it continues to blow otherwise Maxium is a bit flakey. But Normal does not work no matter what.
Also, I just did a partial recharge on the A/C, thinking that maybe that Pressure switch had something to do with it. I pulled a vacuum on the system for about 15 min. then in put 16 oz, the Clutch on the compressor finally started kicking in and out. I'm going to put in another 16 oz and see if it settles down.
I'm all ears....
I'm all ears....
