Antz81
With winter approaching I plan to sort out a few of the oil leaks I've been ignoring on my '81.
First is from the engine. I believe it is the rear main seal causing the leak. (engine oil on the bell housing) Since I've got the pan off I'll do the Pan gasket at the same time. Anything else I should look at while I'm in there?
Second is the diff. I believe I have a leaking pinion seal, there is always oil everywhere around the front of the diff. Can this be done without removing the diff from the car? (I think I saw a thread on this but can't find it now) I'll also do the front bush at the same time and check the U-joints. Anything else I should look at? The rest of the rear suspension was done not long ago.
If I can get the section of wiring I want I also plan to install a timer to keep the power for the windows hot for about thirty seconds after the ignition is turned off. I'll let you know how that goes.
