6
65 Sting
Hi! I'm a first time Corvette owner having bought a 1965 Milano Maroon Coupe. The question I have is that it seems to have the K19 (Var.1) A.I.R. system on it, and I thought A.I.R. didn't come out until 1966? I have a matching numbers engine with the engine serial number 5121377F0628HE. I thought the HE was a 250 HP motor, but on the code section at CAC, that HE code stands for an Air Injection Reactor manual trans. 350HP engine. Now I don't know if I have a 250HP or a 350HP engine. The engine has Corvette finned valve covers, an alum. intake..GM#3844461, and a Holley R2818A #3849804 4 barrel carb. It has the heat riser choke with a chrome tube going from the exhaust manifold to the carb. and a rubber tube going from the chrome enclosed air cleaner( open on the cowl side), down to a metal tube which connects to the underside of the same exhaust manifold..(passenger side). Any thoughts or ideas?? Other GM code sites say that HE is a 250HP and HF as a 350HP. Are the 65 codes on this site the correct ones?? Thanks for any help offered to the new guy!:confused
