Well , I've collected all the materials that I have read on this Forum. Por-15, New Carpets, Insulation material, Welder and started my restoration project yesterday,
Tore all the old carpet up. Took all the old insulation out and almost passed out what I saw.
I've had a small leak behind the firewall for the past 3 years when it rains. I thought that most of the water would drain out the drain hole that GM had put in. It seems that the water pooled behind the drain hole with disasterous results.
Thats why the welder is in my new parts list. I have a hole that my fist can pass through. Well it wasn't that bad until I started poking around. Or should I say Poking through.
All I can say to anyone else, Do NOT ignore water leaking into your vette!
Anyway with that shock a side, the job at hand was cleaning up the floor pan.
I will post pictures in this thread if anyone is interested in my progress through this job.
I almost forgot my first question:
Have any of you guys filled in that drain hole???
Thanks For listening.
Enigma460
