perry bizzarro
hello ordered a abs relay will try that see what happens let you know will start from there
Perry: Is this the relay you are referring to? It is the Control Module Relay. It has been long since discontinued, however I have a few available. Send me a PM if you think you may need one......... Regards, Chriswell got the relay in today its the rong one or i dont know where it goes 4 pin thought it went behind the drivers seat and it powered everything up it says bosch on it but its the rong one if i find out where it goes i will put it in anyway and go on from there maybe sombody out there knows where it goes rock auto part num is ry304 abs relay
yes it is just came in installed it and the light is out looks like a fix brake control module relay got it off ebay
Perry, I don't quite understand your reply. Could you explain? have an 87 Coupe and in case my ABS has issues, I'd like to know what to do. Are you saying that that Audi Relay from ebay worked? But I am clueless what your ending says about the fix brake. Do you mean there is a Brake Relay and you fixed that instead? Not to be picky, but remember many others read these posts and it's only courtesy to spot check the writing. Thanks.
Darby: I sold Perry that relay on E-Bay; the correct part name is "Control Module Relay", and it's mounted right next to the control module. In the majority of the reading I have done, 90% of the time the ABS light being on is either caused by this relay being faulty, or one or more of the wheel sensors being defective. I wasa little unclear as well on how he was referring to it.............
