Greg Albers
Active member
Hi all
The abs light is on on my dash. I pulled the codes and the only one shown is bad LR sensor. Sensor checks out OK but I still have light.
Should I be able to hear the abs pump self checking when I turn the key to the on position? I have pumped the brake pedal with the switch off and then turned the switch to the on position several times and do not hear anything from the pump. I have a factory manual for my car but do not have the pinout connector to test the circuits. I have a 1990 L98 coupe.
Help!
Greg;help
Help!
Greg;help
:cool
