muzy67
'86vette-I just replaced my hub bearing(dvr side) and NOW my ABS seems to be acting up. On start up-normal, 4mph test normal, than on acceleration(over 5/6mph) the module or pump starts humming for about 10 sec and then the "anti-lock" light illuminates. I did use vasoline when installing the sensor back into the knuckle but only on the sides. I don't know if that could be the problem but I will check the sensor and clean it off and start from there. I searched this forum for like problems with no luck. Any suggestions appreciated. Thanks, Steve
