V
Vrotate
I replaced the u joints on the drivers rear a couple of months ago. To do so I had to remove the entire knuckle. Doing this scewed up my ABS.
When the ABS goes though its' test at 4 mph the anti lock light comes on, disabling the entire ABS system.
I was told that the system would 'reset' after 100 starts. Well its been several months, nothing has happened.
I read that you can pull the trouble code, went to the ECM terminal to ground the slot, and there is no wire where it told me to ground.
Is there another terminal besides the one under the driver dash. A ABS terminal? Maybe under the speaker in the back where the ABS is??? (converitible)
I appreaciate any help!
Vrotate
Vrotate
