I
IndyPaceCar78
I just bought a Calibrati chip (AC Delco) to change the speed that my '87 shifts into overdrive. Has anyone installed this chip, and what were the results?
I was told that it would raise the speed at which the car shifts into OD. My '87 generally shifts into OD anywhere from 41-45 mph depending on the rpms. This seems pretty low to me...
Does anyone know the process of installing it? I'm told its pretty much "plug and play"... Is it labor intensive, and since I've never done this, I'm told the control module is located behind the kick panel on the passenger side floorboard area? I was also told my '87 has a performance chip, and wasn't sure if this would work in conjunction with it, IOF there is one installed....
As always, any insight is greatly appreciated!
Indy
Indy
