ras
Ok guys and gals i am not looking for a debate on what are the best mods for an LT1. I just thought a few of you might want to take a guess at what my rear wheel dyno results will be on 5-17-13 at TPIS in Chaska MN. Here is a list of upgrades i have performed and my vets info.
1995 lt1 (300 hp stock) 6 speed coupe with 68000 miles.
.039 head gaskets
52 mm bored stock throttle body with air foil.
stock injectors
cut open air cleaner lid and added new k&n filter
stock intake ported
stock heads with home port & polish, valve job and milled .006 to clean up.
obx long tube sst headers with 1.7" primary tubes and 2.5" collectors
replaced all cats with 2.5" sst pipe, installed x pipe and still running stock mufflers (sounds great and no drone)
new optispark (delphi), plugs (ac delco 41-906) and wires (taylor 8.5mm)
bypassed throttle body coolant
comp cams 1.52 ratio magnum rockers and pushrods
new antenna mast (will turn radio off for dyno run)
and of course a custom tune by TPIS on dyno day.
This was just a basic head gasket job with a little "well since i have it apart". Currently running good but i am sure the tune will help alot.
Take a guess at max hp and torque and i will post the results.
.039 head gaskets
stock injectors
stock intake ported
