S
ssvett
I have a 90 Corvette in the shop, we are doing some exhaust work, paint work and AC Work. The problem comes with the AC work, it was low on freon and the compresser would not come on. I thought will, it's low on freon therefore it will not come on. So, I went ahead and converted it to 134A and the compressor will still not come on. I have check the fuse at the fuse block, and have checked it at the low pressure, high pressure, and some other switch on the high side and have no voltage to any of them. Is there another fuse or switch somwhere or could the problem be in the controls..........Thanks for your help........Steve
