L
ltmark
You folks, and this forum, have been absulturle great on my efforts to get my '85 running in top form.....I think I'm down to my last major problem. I've struggled with my idle, not high until warm, and although it does pretty well when warm, it still searches up and down a bit.
I have read on the forum and in my service manual, that the ECM uses AC readings (even when not turned on) to choose the proper idle. My AC is NOT currently charged, BUT the AC pressure on/off switch is "open", ( with the AC switch not even on!) as though the pressure in the system is too high and causing the switch to cycle open.
I've done the proper setting of the IAC, TPS and all other obvious idle related funstions over and over.
New IAC, TPS, EGR valve, all vacuum hoses replaced, coolant temp switch & sensor, rotor, cap, wires, plugs, etc. etc, etc.
Runs great when warm and idles pretty well, other than the searching.
Any of this cause any light bulbs to go on?
