Hi everybody, i have a really annoying problem with my 2007 corvette C6 LS2, some time from now, the problem was minor, but now with time, it got worst and worst , now, i can´t drive my vette.
While driving, if i hit a little hole or a small bump or whatever it makes the car vibrate under the car, most of the times the RPM gauges and the mph gauges go up and down really fast and then the gauges go back to normal,(i can hear the car accelerates by itself ) AND AT THE SAME TIME THE CAR SHAKES LIKE IF ONE GEAR GOES DOWN, meaning , if I’m driving ( my vette has an automatic transmission ) and I’m in 3rd gear, while driving, go thru a little hole or something that will make the car shake or vibrate relatively hard, it will make this both malfunctions AT THE SAME TIME, gauges go crazy for a few seconds and the car will shake / feel like there´s something wrong with it and then go back to normal.( LIKE GOING DOWN 1 GEAR BUT AGGRESSIVELY / HARD )
I alrdy took my car with 2 of the best mechanics near my city, and so far nothing, i drove my vette yesterday , supposedly we found what it was, we found some wire under the co-driver carpet where you put your feet, there is a fuse box there, and the wire was a little bit trampled and out of place, we put that wire back in place and protect it with some dealer sponge to avoid future problems, after we fixed that, took a drive and NOP, still had the problem.
My mechanic has the dealer computer / scanner and there are no codes of anything, the only one he got was the U1000 AND P0300, the u1000 is miscommunication from modules 2 and 4 , or series 2 and 4 something like that.
We checked the fuse box from the engine, wire from the transmission (under the car ), oil from the engine level its ok and transmission oil, both are brand new just a few weeks ago, brand new thermostat, brand new air filters, coolant ok, and some other things brand new installed just for maintenance .
The next step is to check the spark plugs and the wire, but i don´t think the problem will be there, i believe there is an electric problem, and i haven´t found it yet ...
I would really appreciate any help i can get from anyone to solve my problem .. i just can´t drive the car anymore and it makes me feel really sad ... Any questions about this issue please feel free to ask .
Alex
Alex
