kalmwill
Hi Folks
I'm looking for some advise on how to get to the courtesy light delay timer. It is located on the inside of the fuse panel, attached to a wiring harness, behind the large passenger side dash pad. ( I found its location on a wiring diagram in my manual.) My problem is that I can't determine how to remove the pad to get at the timer. The pad is fastened to brackets on the inside of the dash. I removed the lower carpeted assembly that houses the footwell light but that didn't seem to get me anywhere. I was thinking that perhaps the whole top dash deck, located under the windshield, should come out to create access to that area. I tried but was not able to remove the deck. I didn't want to force anything lest I break something. Before I start into the job again I thought that I would consult this forum. Any help or advise from anyone who has been there would be greatly appreciated.
Bill
Bill
