Help! Active handling again
philly aka KILLADELPHIA,PA.
2000 c5 silver coupe blk interior
Drove up to POCONO S last week . rained alot . one of my tricks is to whip rear end out @ a 270 degree turn . SERVICE ACTIVEHANDLING @DIC Then service ABS/ TRACTION CONTROL SERVICE stayed on for 10 miles until reached grocery store. SHUT down , DIC& dash stay lite.. Go shopping come back read codes C1243 C H. TRACTION /ACTIVE works ok.. next day take ride, still drizzling ,stop @ store, engine still running ACTIVE HANDLING WARMING UP @ dic ,waited 5 mins never went out ! shut off .return all is well. 2000 c5 replaced active module 2 years ago !!:ugh any ideas :happyanim: :v
Disassemble,Clean and Inspect Ground splice pack at grounding point 7 (Top of chassis behind left hood henge)
Clean and Inspect grounding point 9, should be 1-3 wires on top of chassis under battery heat shield.
Clear codes,Drive and see what happens!:D
Active Handling Warming Up, Failed Smog, Incomplete test - solved
Failed smog 2 weeks ago, incomplete test, HP Tuner confirmed all emission test incomplete.
Car 1999 C5 Auto, running well, no codes.
Checked all fuses, relays, ground points, pulled console - checked voltages everywhere...looking too deep!!!!
Only tale was Active Handling Warming Up displayed for the last 6 months - just got to be normal.
When temp IAT not outside is below 14 - active handling display warm up as a warning for 7 mins.
HP Tuner showed Intake Air Temp. of -39? WTF.
Replaced IAT Sensor 25$ part. Passed smog - active handling warmup gone.
