L
lyle nelson
Has anyone added after-market XM to a C5? If you use the FM modulator type, where did they install the bracket and antennae? Happy with it?
thanks
thanks
Got the MyFi at Circuit City!lyle nelson said:hey, I'm in okc as well, what/ where did you get "myfi", I already have the Delphi set up, in my truck, and thought about adding the same car kit in the 'vette so I can move the unit from car, truck, home, etc.
r
AZMike said:dfontanese,
These guys make hanesses to OEM radios that allow you to use the CD changer port as an AUX input. If anyone has what you're looking for, it would be them.
WWW.peripheralelectronics.com
BTW: Excellent color choice on the coupe!
AZMike said:Bummer - I'm having the same issue with my aftermarket Eclipse head unit too. No one makes any adapters for it. I guess I'm doomed to listen thru the FM modulator. I guess I'll just have to keep the speed high enough so the wind noise drowns out the static!
AZMike said:I'll just have to keep the speed high enough so the wind noise drowns out the static!
KD4WCL said:Make sure your FM radio station is tuned to the proper frequency. Some of these FM transmitters offer as many as 5 frequencies, and being at 89.1 instead of 89.3 (for example) would give you a noisy reception. Move through all of the low FM frequencies on the dash radio to check.
Does the factory Bose system have an auxiliary input so you don't have to use the FM modulator
