Eagle85C4 is exactly right. Adding a relay is rather simple, and kind of fun.
First, you need to get a simple cooling fan relay from the auto parts store for say, oh, really almost anything. It is best if you choose a really common car like a 92 Buick Century. That should cost about $7. Now, go to the junk yard, find a 92 or equivalent car and snip out the fan relay harness where it plugs in. Go ahead and get two or three of them and some extra relays.
Now, back at your house, use a 8 or 10 gauge wire. Go from the battery, or 12+ terminal on the starter to about a 25 amp fuse. You can make a fuse real easy by clipping the wire in two. Crimping a female spade terminal to each end, then plugging the fuse into the female spade terminals. Wrap some electric tape around the bottom, and you got it.
Now, go to the hot side of the relay with that wire. Come out of the relay on the other hot fan side and run that to the fan 12+ and take the wire out of the fan to ground on the chassis.
Now, find a good 12+ ignition only powered wire. Run that to the coil part of the relay. Run the other side to ground. What this will do is make the pusher fan run all the time when the key is on. Or, you could take the ground side of the coil, run it into the car to the switch, then the otherside of the switch to ground. This way you choose when you want the fan to run by clicking the switch, which will close the ground circuit, which will close the coil, which will connect the main power to the fan. This will only happen when the key is on, thus you can't run your battery dead by forgetting to turn it off.
Of course, you use the junkyard terminal connector end to put a fresh factory look to the relay, and mount the relay where it is easy to get to. I suggest behind the battery on the firewall.
Good luck!
