Ok, I'm buying the parts I need to manually control the auxiliary fan I'm installing. What I'm hoping to do is run a wire from the battery + side to a switch under the dash and out to the + side of the fan motor, and another wire from the - battery side to the - fan side. I want to have the fan work even when the engine is off, and I'd prefer not to have to take the dash apart to run off an always-hot circuit in the fusebox. Is there a better place to tie the wires to? I know some people have done this mod; how do you all work it?
Thanks...
[RICHR]
Thanks...
[RICHR]
