C
celeryman22
Hello, I got the timing on the vette set pretty good I think. But right now the car idles really high. I just got done rebuilding the motor and the carb was just rebuilt by the local carb guy. I read that I should connect a gauge to the vacuum line and set the idle to achieve max vacuum. Right now I have no dash on the car so I cant tell by the RPM's what its reving at. By the sounds it seems to be around 1500 or so. I dialed both idle mixture screws in and dialed them back 4 turns. Should I start to dial them in to lower the speed? What vacuum port do I connect to.
Any help would be great.
Mike
Mike
