94LT1
Hello all,
Had my '94 for nearly 8 years now and not had the need to request any technical support as has always run without problems but that has all changed after a visit to a garage for it's annual UK m.o.t. test (yearly inspection). Briefly:
62k mileage car completely stock.
Emission test runs in 3 parts: 1st fast idle test/2nd fast idle test/natural idle test.
The results for the 1st idle test CO .43%
HC 20ppm
Lamda 1.01
During the second idle test the engine struggled to make the numbers to pass but was close so was revved a little harder to get to temp (?).
Suddenly CO changed from .43% to 10.85%
HC changed from 20ppm to 287ppm
Lambda changed from 1.10 to .72
On the final natural idle test the CO should be .30% max to pass but was now 46.3%
I've checked the codes and only showing a C12.
Just about to take for a drive to see if any new codes set and now the battery is not charging so staying put for the time being.
I've looked at all your very usefull history file of problem solving and suggestions but not really sure what to be doing next!
Any suggestions?
Many thanks,
Steve.
HC 20ppm
Lamda 1.01
Any suggestions?
Many thanks,
Steve.
