wjw1741
I am having issues with my original carb on the .327 250 HP. Every once in a while the engine will cut out, usually 3500 or above RPM. NOw, I have had the carb rebuilt twice in two years and the same problem is there. The engine was rebuilt at the same time, so I am still thinking its a carb issue, especially since it only happens at certain RPM's. Now someone told me it could be the butterfly chokes not opening precisely when they should, so rather than spend another bunch of money to fix the original, I was hoping to get an affordable after market edelbrock, but it says that it requires a 5 1/4" air cleaner center hole, and I do not want to do any MOD to the engine block at all, so is there an affordable alternative? Any suggestions are appreciated.
Once I find out the carb is the issue, in the future, I could spend the $800 and have it totally rebuilt at Paragon, but until then, I was hoping for a cheaper and quicker fix.
Warren
Warren
