Peer81
Hello everbody,
Today a great day overhere, the first parking lot trackday!
So in short, started the track without any problems most in 1st and sometimes 2nd gear. I think somewhere at 3/4 of the track there was a 180 degrees turn. Well, my turn stopped at 360 but that is were the fun is.
After that I feld my p/s steering was gone but with "manual" steering I finished the track. Checking the fluid it was at the bottom of the stick (a few mm under the add point). Added about 1 theacup with fluid (to get it past full) and drove some tight turns to get all the air out. Most of the power steering assistance came back but also has a grinding feeling in the steeringwheel when turning the wheel.
I didn't continue the trackday and at the end of the day I drove home. At home got the front of the vette up in the air. Got the lid off the steeringpump, started the car and starting steering from all the way left to all the way right and back, did that for 5 to 6 time and all seemed to be nice again. When going from left to right almost at the limits the steeringpump seems to make a light short peeping noice but its just short.
Lowered the car and took her for a spin. Powersteering is all the way back but the grinding feeling is still in the steeringwheel when I turn into a corner. So what could this be. I already checked the shopmanual but I can't find the same problem symptoms.
Btw. No leaking from the system (also don't know why there was not enough fluid in the pump. Pump is a new or rebuild one from Rock, installed I think 6 months ago. The belt tension is good, powervalve was rebuild a long time ago but is centered nicely also no leaking. Power cylinder is new and hoses are new. Steering house rebuild by me and adjusted with proper dial torque wrench.
I'm thinking the pump is the problem and needs a rebuild but maybe I'm thinking into the wrong direction?
Thank you,
Greetings Peter
Thank you,
Greetings Peter
