LeeAnsell
Im puttting a aftermarket raido in my corvette everything seam to work on the raido but can't get any sound out the speakers. Has anyone done this before?
I have not done it but I've read about it before. Did you change the speakers too? I believe your speakers are amplified and specific to the Bose system that came in your car. Unless your new radio is designed to work them, you'll also likely have to change them also. If doing that, you'll want to run new wires to the speakers also.
You'll likely want to do further research on your audio system to get it to work.
I did some more research on the Bose system and found a connector on line that will work with any aftermarket raido and run the Bose spekers.
Thanks for the response on this post.
