Stallion
If you put in a more agressive cam, it would keep the valves open longer for more air flow, resulting in more hp, correct?
But, if you were to do this, what would it do to the timing? Wouldn't the spark plug need to be delayed for the combustion to take place? Or would you not have to fool with that?
In other words my question is, as a result of cam change, would you need to monitor/change other things? I don't understand how if you would put in a more agressive cam that the timing would still remain fine.
Thanks!
TR
Thanks!
TR
