Air Conditioning Problem - 1995 Corvette
kf4eve
New member
I have a 1995 Corvette that the A/C quit working What could be some of the thing I should look for when I go to an Mech.?
Make sure that the compressor has a good tight belt on it, and then check for adequate Freon in the system.
Welcome to CAC!!!
enjoy!!!
Welcome to the Corvette Action Center.
I'm going to move your thread into the C4 Tech forum for greater exposure.
Check fuses related to air conditioning. If they are ok and if you are familiar with both electrical work and have the required tools, read the factory service manual for diagnostic information. If the problem is electrical, ie: failed blower motor, failed control head or other electrical problem, the fix, while maybe not cheap, the repair could be a DIY activity.
If the problem is with refrigeration, repair may require special tools and the equipment necessary to evacuate then recharge the system.
Also, with a car that old from which the refrigerant has leaked you're looking at a replacing the drier, condenser and hoses. In that case, repair will not be cheap.
If you are not familiar with A/C work, take the car to an air conditioning specialist.
