D
DaleB
Howdy Folks
Old Dumb Dale turned on the 94 Coupe and being a bit warm in South Texas, turned on the A/C and though the fan did blow and blow hard, no cool air came from within. Being quite old and not too smart, I went to the local Autozone, bought a tester, R134a and went to work. Seems that using the chart, I located what I ass/u/me/d was the "low side" and the tester fit just as advertised, however it came up with a reading of 110 lbs, which the chart said I had hooked up to the wrong connector, do not add refrigerant. However the other connector is larger and won't accept the testing/refill kit.
Maybe one of you fine folks might pass on a few words of wisdom to this old fella. If you figure I won't be able to understand, which I might not, maybe a name of a half way honest A/C mechanic around San Antonio, Texas would be appreciated.
:confused Thanks Dale
