S
Spinout93
Hey guys - My 93' a/c is acting weird. If I set the temp. controller inside to maintain 72 degrees the compressor will cycle on and off as if it is low of ref. but when I touch the accumalator and the return line they are extremely cold.
I put a digital therm. in the air vents and while it is running it will produce 48 deg. air. After the compressor cycles a few times the green light starts to blink at the controls. I do not have any codes to read. Any suggestions?
Thanks again.
Thanks again.
