P
pauld
My AIR pump belt has been dissconected for nearly a year and when I was cleaning the engine bay today the rubber hose that connected to the exhaust maniflold just snapped off at the top of the steel pipe that connects down to the manifold. I have always hated the mess of the rubber hoses so I welded a disc into the top of the manifold thus sealing it again.
I then did the same on the other exhaust manifold and removed that pipe also.
My question is this, is this all I have to do or will this effect the running of my engine in a negative way, I see most people have removed the AIR pump totally, but for now until I actually remove the thing, will this be ok or will it cause any vacuum leaks. Will I have to cap anything off???
Engine seems to run fine at the moment.
