airbag light
garylt
DesMoines Ia
2005 Corvette, Black 6 speed Coupe
Has anyone had a problem with the plug under the driver seat airbag making the airbag light come on. It's a 2005 c6
Toms007
Moderator
Southwest Kansas
2007 Atomic Orange Coupe
Yup, it's a common problem. I took a zip-tie and wrapped around the plug to hold it together tightly. I used an electrical cleaner to clean the connections first. I talked to the Chevy dealer about the recall notice on this problem, and their solution (from Chevrolet) is to remove the plug entirely and solder all the wires together....not what I wanted to do. As I asked them "What if I need to remove the seat for some reason?" ... "Well, you'd have to cut the wires." ......."UH, NO, we're not doing that."
I refrain from moving the seat too much as that seems to aggravate to issue.
garylt
DesMoines Ia
Thanks , I will clean the pug first and see if that helps. will cut the wires if that will not fix it. If the the light is on from under the set are all the airbag not working.
