I posted this on the other forum too, Pfadt Racing Website, the Performance Street setting is what you want...Paul
Please post the alignment specs again for an 06 convertible The car is used for normal street driving. I am interested in maxium tire wear.
Thank you very much.
Don
Forgot to mention,I run 34Lbs Front,29Lbs Rear. I get a nice flat uniform tread ware!Junk's numbers are a good place to start and then, after that, I'd watch the tire wear then adjust pressures and camber accordingly.
For Maximum Tire Ware I set up C5's and C6's about the same depending the roads it's driven on.
I got 55,000+ miles out of the first set of Kumho ASX All Seasons on my 03,Looks like I'll be getting about the same on the second set!
Lt Front 0* Cam,6.5* Caster
Rt Front 0* Cam,6.6*-6.7* Caster : Depending crown of roads it's driven on.
Toe Front 1/32 in.
Lt Rear 0* Cam
Rt Rear 0* Cam
Toe Rear 0-1/64
The car will steer easier than factory settings.
WARNING!~! These settings WILL make the car a handful in excess of 125-135 MPH!~!!!
If the car feels too light in the front after alignment,You can take the front toe in up to 3/32 and it will make feel a little heavier!![]()
Happy Motoring!
How different would the specs be for a Grand Sport Coupe?
If best tread life is the goal, the numbers given above are a good start be it a C5, C6 base or C6 GS.
If you're a track rat and replace tires frequently, that's a good street/track alignment. If you're a street driver only and you seldom drive aggressively, with -1.17 and -1.22 in the front and -0.9 and -0.7 in the rear, your car will likely wear out the inside of both its front tires before other parts of the fronts and the rears are worn.
HI there,
Lets be clear on a few points.
Toe, in the positive sense, is critical to directional stability. 0 toe can create a little wander, whereas +.1 degree will assist in not having to constantly correct your steering input.
Camber, is more for cornering faster, and can create alot of tire wear as indicated above. If your tracking, you want MORE negative camber to enable faster cornering. In street driving, its not really that necessary.
CASTER, in the positive range, will create BETTER high speed stability with higher numbers. For example, +7.0 is better than +6.0 for high speed stability.
What NOONE talks about is TRIM HEIGHT. When a vehicle has an alignment done, ESPECIALLY CORVETTE, trim height or RIDE height MUST be checked and verified to be within specification. If too low, bump steer and other ride quality concerns can unsettle the vehicle when driving agressively. If the suspension cannot travel correctly, NOTHING will work right when going over rough roads.
All specifications interrelate and this fact cannot be ignored. Trim height validated FIRST, then proceed with 4 wheel alignment.
Allthebest, Paul
Paul,
What are your recommendations for a ZR-1?
So if we are dealing with a stock vehicle that has not been lowered or messed with......what would change the ride height?
