M
myonnone
A couple of questions for all you alignment experts.
I've just finished rebuilding the front end (upper/lower ball joints, contol arm bushings, tie rod ends, stabilizer link bushings, stabilizer bushings, ect.) of my 66 big block and want to get it aligned.
I've also just mounted a fresh pair of Michelin 215/70/15's on 67 ralley wheels. Now the questions.
Should I stick with the stock alignment settings?
Am I better off with some other setting due to the wheels and tires I'm running?
Many thanks in advance.
Martin
Martin
