67HEAVEN said:Larry,
This is bad news. Sorry to hear that it's down deep.
This is a real stab in the dark, but could aggressive surface prep, in advance of even the priming or sealing, have dug too deep into the fiberglass?
The problem is restricted to the deck lid, right?
jreeves said:Larry
Could it be residue from a chemical stripper? (I don't recall if you removed the old finish mechanically or with chemicals)
vette-dude said:I have seen this before in other paint jobs and for what it is worth I think that the problem may be the compressor. The painter probably has a filter and trap on the line but did he have another final filter on the inlet of the gun and was it new if he did? I think you might be getting some compressor oil or water contamination in the airline. Just a thought and a thing to consider before you do the rework. Also, did by chance you mix any fish eye eliminator with the paint mixture? I have been told this is not recommended with two part paints using a catalyst. I tried it once by mistake and it left a mess that took me forever to straighten out so I feel your pain. Sorry it happened and hope you have better luck on the redo.
Randy
PS: The delamination problem would not be a result of the above. That has to be something to do with the glass repair work or maybe a primer solvent incompatibility problem I would think.
wapaugh said:Man, Larry...
Sorry to hear about these problems. You are so close to finishing! It makes me wonder what sort of problems I might run into when the tired old black paint comes off mine. It's only been sitting since 1975 with car parts and who knows what else stacked on top of it. And I thought 3 inches of rat droppings were going to be the worse of it!!! How would one ensure the fiberglass is stable before applying new paint? If glass rot does exist, shouldn't it be the responsibility of the paint & body man to find it and repair it or is it not that simple? When I had my 64 done years ago, I know my painter worked and inspected every square inch of the body for hairline cracks or any abnormalities that might show once the car was painted. The end result was fantastic and held up for as long as I owned the car. It just seems to me that rotted glass should show some sort of discoloration or perhaps bead water differently during wetsanding. But I don't know...I'm not a painter. Hope you get this resolved.
Wes
Mac said:His explanation makes sense... Funny the paint guy didn't get this or was he more concerned about covering his liability?
-Mac
wishuwerehere82 said:Larry,
I think having been stripped and left outside for years may have something to do wth it. Pinholes in the surface allow water to enter the fiberglas and freezing and thawing do the rest. It certainly looks like the surface prep has been forceably delaminated from the mat. Ice would do that.
vette said:Larry You said the car was stripped before you got right? If some one used the wrong stripper and left it on the top surface to long it could have caused the glass to delaminate. And would not show up till the sun heated it up. I saw this once on a car that a guy stripped with to strong a stripper and it riuned a few spots where it sat to long. Just a thought. But for now we must see if there are anymore and then fix the problem.
