T
Tinker
On my 71 I upgraded to a 135 amp alternator because of the spal fans. Is it a must to run a bigger wire to the alternator and if so how?
If the gauge of the wire is the same as or smaller than the wire from the battery to the starter, then it can go to the starter. I plan to run mine to the starter via a junction block to which I will also wire the Spal Fans.Bob Chadwick said:The Powermaster site recommends upgrading the wire or you can actually lose power. It has the recommended sizes on their website. I'm not sure where it goes to. The battery or the starter.
Nice! Where did you buy the CB?photovette said:I used a 4 gage wire from the alternator to the starter/battery connection. I used a circuit breaker and got rid of the fusable link.
I'd run it direct - alternator to starter.Tinker said:Do I need to run the wire from the starter to the horn relay, then to the alternator, or straight to the alternator
Sorry man, don't see where you get 5 hp outta that.....750 watts/hp roughly...times 5 equals 3750, divided by 12 equals....312 amps, roughly....photovette said:I bought it here: http://www.wiringproducts.com/
They have everything you need to bring your 'vette's wiring and electrical system up to aviation standards...
I also installed a high current relay and a vacuum switch--when at WOT, the relay opens and totally unloads the alternator except for the feed to the distributor. This does two things, it increases available horsepower by dropping out the alternator--about 5hp+ I estimate--and increases voltage to the distributor (no load condition) thus increasing spark energy.
