A
Ala75Vette
I'll try to keep this as short as possible. I have what I suspect to be a drive train vibration, possibly from the drive shaft/u-joints, or possibly from the transmission. I suppose it could also be from the engine, but I'm doubtful that's the case.
I recently got rid of a lot of my vehicle vibration by tightening up the exhaust. Amazing how big a difference that made. I had the wheels balanced, still vibration. I checked the drive shaft u-joints per the Hanes (the long stretch of road, check for consistency of vibration at affected rpm in each gear, then do a 10-15 mph throttle/off throttle check for 'thumping'), and in this 'driving' test could not positively identify the u-joints as the culprit. Have not jacked the car up and visually checked u-joints/drive shaft yet, but will do that this weekend.
Had the harmonic balancer, timing chain & gears replaced recently. That also got rid of a bunch of vibration.
My (4-speed manual) transmission leaks, and is hard into 2nd and 4th when it's cold, but fine once it warms up.
The vibration isn't overwhelming, but enough to be annoying. I'm just afraid if I don't deal with it soon, it'll transition from the annoying phase to the $$$$$ phase. It occurs mainly at 1900-2000 rpm, but I have a real hard time telling if it only occurs with clutch/no clutch, only while I'm in 2nd or 4th, etc. I know that doesn't help much, but any ideas?
Thanks,
Frank
Thanks,
Frank
Frank
