I am recharging my A/C system after completely replacing the entire system. I have vacummed the system down and it holds vacuum for over 24 hours with no movement on the gage so I assume I have a tight system. My question is, the temperature in my garage is only around 40 deg F, is this warm enough to pull any moisture that may be in the system out completely, or should I wait until the warm weather arrives here to finally vacuum and fully recharge the system.
