M
mike
Well, being a new vette owner,(98 artic white, white top, tan interior) I purchased an additional fob from corvette central. The owner couuld not locate the second fob that camer with the car........Got the new fob, replaced the battery just in case the one in the new fob was bad, and tried the training process in the owners manual.........no luck. When I go to the options and go to the blank indication, right after the english language screen, I hold the #4 options button, sometimes for over 2 mins hoping for luck, but do not get the fob training message. The C5 specialists suggested disconnecting the negative battery terminal for a minute and try the process again. Same results, I don't get the fob training message. The original fob ( holding down the buttons) gets an acknowledgement from the vehicle, and no problems. I tried a new fob battery for the new fob and even exchanged the battery in the old (original) fob in the new unit, still no luck. I would appreciate suggestions at this point and will contact corvette central re: any process they my suggest
thanks
mikeionatlanta
PS, if this is the only problem I experience with the car, it is still the closest thing to..........well, you know...........
thanks
mikeionatlanta
