I have a similar problem with my head lights. "OFFBEAT OCTANE" posted
dim drivers side head lights . My '71 , low beams work great, when I click on
the high beam, the low and high beam on the right side are dim. I have replaced
the bulbs, sprayed contact cleaner, same results . Someone told my son the
wire terminal plug is bad . I check and can't find anyone that has a high
beam plug. I will probley have to go to salvage yard. on GM 4 light system
are the plugs the same as the one that on the '71 ? I am talking about the
older GM cars. Thanks in advance for any help.
