D
drmusic
Hi everyone!
I have a horn problem that I can't figure out (even with previous posts). I have a 1990 Vette.
It worked until last year! Now it only works once in a great while. My brother put a keyless entry in it and when he was putting the dash panel back in, the horn worked, but then it stopped again.
The relay doesn't click, but the horn works when the alarm goes off. I took the caps off (the '90 has two caps on either side of the air bag) and tried making the horn work with a jumper - no relay click - nothing!
Does anyone have any ideas? How about the wire colors? I have the underside of the dash apart and I don't see anything out of order. Are the horn wires pink? Is the relay to the right of the steering wheel?
I am going nuts not knowing what is wrong with this thing!
Thanks in advance!
Scott
Thanks in advance!
Scott
