A
Alan86
On Monday, I go out to my car in the morning to go to work. Turn the key, dash lights up, everything looks good, engage starter, and no starter. Leave the car at home and take my Tiburon to work. :cry I come home try the starter, and it worked. I go to fill up with gas, and when I try to start after filling up, no start again. I try for 40 mins to start the car, but no luck. I get a tow truck to take my car home.
On Tuesday I try again, no start.
Today (Wednesday), I remove the starter and test it against a 12 volt battery, it works.
The question is, do you think that it is the neutral start switch that is faulty, or is it the dreaded VATS being set every time I put the key in the ignition. I have tried another key with the same no start.
Where exactly is the neutral start switch on an 86 4+3? I have removed the hush panel and tried to look at the clutch pedal, but I cannot see any switch. Totally :confused now!!!!
